Racor 120AT spin on fuel filter on a Yanmar YM2000
Have a neat project that you are doing with your tractor? Restoration, modification, customization, whatever. Post it here!! We want to see it.
Coda1
Postby Coda1 » Sun Feb 26, 2017 11:15 am
I installed a Parker Racor 120A fuel filter/water separator on my YM2000. I went with the 12T 10 micron filter. I can also use the 12S 2 micron filter but think that would be overkill and require replacement too often. Unlike the OEM filter it has a water drain. I made a bracket that I bolted to the fuel tank support bar. There is just enough room to fit the filter between the bell housing and the throttle linkage. I used a shut off valve from Anderson Brass in front of the filter. Since the YM2000 is the grey version of the YM240 it would likely fit that one as well. Second picture is the bracket I made bolted to the tractor before I attached the filter.
Coda1
Re: Racor 120AT spin on fuel filter on a Yanmar YM2000
Postby Coda1 » Sun Feb 26, 2017 11:21 am
Here are the dimensions for the bracket in case someone else wants to make one.
Postby Aaron » Wed Mar 01, 2017 2:53 pm
Looks good! I like it.
O~o\
Postby O~o\ » Tue Jun 27, 2017 11:40 am
"The filter it has a water drain."
That would be usefull.
Return to “Tractor Projects With Images!”
Users browsing this forum: No registered users and 1 guest
