October 2022
Not that much use for the trac this time of the year, have only been towing the trailer around few times with lumber to do some firewood for the winter.
Did some research to replace the air filter for the trac, as I cleaned the old one few months back and it was filled with gunk. I believe it hasn't been replaced nor maintenanced for the last few years. I really think the airflow will be much different with a new filter, the amount of dirt I was able to get off the old filter while cleaning it was just ridiculous.
A replacement filter from WIX would be 46270, the measurements are the right even though some may say WIX doesn't have the right filter for these tractors. That part was however very difficult to get around here so I found with a little bit of fiddling around a
Hengst E750L filter which was ordered & put into place. The Hengst package had some cross-reference numbers on it (which is very exceptional) and they state a Mann C 934 X would be equivalent for example. Just make sure that the filter will bottom out before the top part will start to prevent the filter fully to seal properly at the base.
Replaced the current mounting point for the heating element cable and welded the mount on the front beam directly.
Next thing on the list was adding some lighting to the tractor because it is getting pitch black during the evenings already and during the wintertime some proper work lights are pretty damn nice to have while snowplowing.
I had the lights purchased last November already but wasn't too keen to mount them onto place until now...
The right hand side had mounting holes premade for the original round-halogen light, which wasn't in my tractor anyways, it had been broken or removed before my ownership already. For the left fender I just copied what was on the right side. 1 hole for the mounting bolt and 1 hole for the cable and a rubber grommet.
Certainly the new lights wouldn't work without electricity, so I had to fiddle around with the wiring. Inspired by the fuse-convert-kit available I decided to change the fusebox on my tractor as well, though I haven't had any issues with the original fuses yet, but it will be beneficial to have few spare fuse slots available for future needs as well.
This is how my original fuse box looked like. It isn't the same that uses the metal slats, this is for glass tube fuses. I think Yanmar have had different fuse boxes they used, or it might have changed during some manufacturing year. This makes things more straightforward since the original box already used the quick connectors which would fit into new fuse boxes.
This is my foundings regarding the wiring, from top to bottom (use with own discretion):
- White/Black wire: 12V feed from ignition switch. Powered only when the key is in "ON" position. It currently feeds all the electrics from this fuse box.
- 5A fuse, Red+Red wires: Warning lights in the dash
- 10A fuse, Green/Black wire: Blinkers/turn signal lights
- 10A fuse, Green wire: Horn
- 10A fuse, Red+Red/Black wires: Original driving lights (front), instrument cluster lights (backlighting) and original rear light
I didn't check if the Thermostart is run by any of these fuses, but I think besides it there are no other electric components in the tractor, so it is very simplified in terms of electronics.
The new fuse box will be slightly larger and will be using side-feed wires instead of back-feed like the original one, so I did have to drill an extra hole for the wire feed-in and a new hole for one mounting bolt since the original holes wouldn't match up with the fuse box model I chose.
Fuse box bolted in place with thru-bolts and nuts, for the wire feed hole I used a pass-through item used for boats (wires, steering cables etc.) to prevent any wires damaging from the sharp metal edges. I had to extend the original wires since the new route for the fuse box would be slightly longer compared to the original one. The new fuse box has 10 slots, so that's 6 extra vs. original.
Original electronics made in the new fuse box. The new fusebox has lights which tells you if you have a blown fuse (in the pic one fuse was removed acting as a "blown" fuse), neat little feature but quite useless to my mind. I used these flag-shaped connectors to make the wiring more neat, and I really like the outcome!
One stumbling block was the connectors itself, since I found out that you should have a special tool for these connectors. Obviously I didnt have one so with trial-and-error I found out that with water pump pliers you manage to get a quite decent crimp as you get pretty damn good force just next the pivot point of the pliers. Make sure you use ones with shaped jaws that has space for the connector so you won't deform the whole connector. (Shame on you all Channellock fans out there in the USA
The rear wiring assembly got some attention next and I ran the new wires together with the original wiring into a nylon wire sleeve with heatshrinks in the end and electrical tape in the Y-branch.
Then I needed on-off switches and decided to mount them on the panel below the instrument cluster and steering wheel since it is easily available to handle the switches, has quite a lot straight surface for switches to mount on and plenty of room back of it for the wires etc.
The upper blue switch was added for a front light (might add later on) and the lower one is for the rear lights. Turned into cop vehicle simultaneously
Also marked each wire with some tape and pen which components they are running.
Lights working, yippee!
That's what the outcome looks like, not that much can be seen from the fuse box with the panels in place and the fuse box mounted in the original place. Definitely a safe place and won't accidentally bind up any wires during operation.
The original coolant overflow bottle was very stained in yellow color and the sensor seal had a small leak in it, eventually emptying the overflow tank within a month or two, so I decided to replace it. The original place for the overflow bottle is quite small and I couldn't find any proper tank that would fit in (and preferably having a sensor in it) so I had to bite the bullet and order a replacement part. The replacement doesn't have a sensor in it, so will have to see if I can sort it out since I wouldn't want to remove a (working) system that has been originally in the trac...
The whole fuse box remained to be feed through the 12V supply from the ignition switch. Do you think it is OK, isn't there quite a lot load for the ignition switch to carry? The original wiring wasn't that thick either. I was thinking to replace the 12V feed directly from battery/starter motor with thicker cable, and have a relay between which would have the signal from the original feed line (from ignition switch). Any suggestions?
