YM 2010D paint job
Have a neat project that you are doing with your tractor? Restoration, modification, customization, whatever. Post it here!! We want to see it.
GBuford4372
Re: YM 2010D paint job
Postby GBuford4372 » Wed Jul 22, 2020 5:05 pm
Here you go
GBuford4372
Postby GBuford4372 » Wed Jul 22, 2020 5:07 pm
Here you go...
Postby winston » Thu Jul 23, 2020 4:49 am
Looks like a new one! I would caution widening the front wheels, especially with a loader.
GBuford4372
Postby GBuford4372 » Thu Jul 23, 2020 5:36 am
Hmmm. Don't guess I follow you.
Postby winston » Thu Jul 23, 2020 10:28 am
You will be putting much more stress on your front axles. Especially with a load in the loader.
GBuford4372
Postby GBuford4372 » Thu Jul 23, 2020 10:50 am
Ok. How do I change that. Remount tires to the deeper side of wheel?
Postby winston » Thu Jul 23, 2020 5:28 pm
swap sides keeping tread pointing the same direction as current.
GBuford4372
Postby GBuford4372 » Wed Aug 05, 2020 3:33 pm
Final pic, bucket painted, grill(damaged) back on.
Postby winston » Thu Aug 06, 2020 4:38 am
Looking good but you still need to swap sides with those front tires before you mess up your front axle.
GBuford4372
Postby GBuford4372 » Thu Aug 06, 2020 9:37 am
Winston, I can't rotate them. The inner diameter of the wheel won't allow it to clear the 4 bolts that mount the steering arm to the knuckle. Not sure what to do with this.
Postby winston » Thu Aug 06, 2020 5:41 pm
Could you take a picture of that area. I am curious. Does it have 6-14 tires?
GBuford4372
Postby GBuford4372 » Thu Aug 06, 2020 6:06 pm
I believe they are 7-12. That is something I've noticed.
Postby winston » Fri Aug 07, 2020 5:44 am
That could be a problem. Although different manufactueres vary somewhat on diameter and rolling circumferenc my reasearch shows the 7-12 to be 24" diameter and 73" rolling circumference. The 6-14 shows to be 25.8" diameter and 77" rolling circumference. All the Yanmar information I have ever seen calls for about 1 to 4% lead on the front tires. If you have the smaller tires yours are going to be a - something % on lead. You might be ok on soft ground but if you handle big loads in your bucket and run on something that doesn't allow a lot of slipage then no doubt you would be putting your 4 wheel drive in a bind. No doubt it would be an expensive change so I know a lot for you to consider. https://www.hoyetractor.com/CTGY/2010TIRES.htm
GBuford4372
Postby GBuford4372 » Fri Aug 07, 2020 5:57 am
Would 6-14 fit the rim I have? Possibly?
Postby winston » Fri Aug 07, 2020 5:59 am
Not a tire person but I don't think so.
Return to “Tractor Projects With Images!”
