3rd function
The Jug
3rd function
Postby The Jug » Sat Feb 19, 2022 2:44 pm
Hello i have a Yamar YM 1510. I have installed a nice frame and then installed a koyker 80. I was looking into putting a grapple on front which will require a set of front hydraulics. It's a newer loader with the most recent loader valve. I would like to be able to operate the loader and grapple at same time. I saw in knowledge base how to put it in series with loader. I will at last resort. I believe on top of the valve i have there is a plug that makes this vale open center or option to make it closed and with the correct fitting it becomes power beyond. Will this work. If so was going to put a electric valve off the power beyond then tee back into the pressure to three-point hitch. Just want to make sure I'm not going down a one-way road to a new pump with this one. Any thoughts would be of great help.
Users browsing this forum: No registered users and 14 guests
