Hi Guys,
Complete newbie here. I just purchased a 1977 Yanmar YM2000 and for the life of me can't find where the coolant drains from the radiator. I need to flush the cooling system....Hopefully someone can help!
Thanks much,
John
Yanmar YM2000 Coolant Drain Plug Location
Re: Yanmar YM2000 Coolant Drain Plug Location
Right rear of radiator, #49. https://www.hoyetractor.com/CTGY/YM2000COOL.htm
Thanks for the reply. I'm still not able to locate even after looking at the diagram. Is it possible the drain hole could be plugged?
Here's a picture for reference. Shouldn't it be in the area of the white circles?
- Attachments
- Yanmar2.jpg (150.72 KiB) Viewed 1275 times
- Yanmar1.jpg (152.34 KiB) Viewed 1275 times
On the other side of the radiator.
- Volunteer Poster
It probably does'n't have one. you drain the block or lower rad hose, at least on my YM2000B.
Yes that is what i was thinking. There's no drain plug. Only way to do it is remove lower radiator hose. Thanks.
Users browsing this forum: Google [Bot] and 11 guests
