jd-950 4whd
rcranford
jd-950 4whd
Postby rcranford » Tue Jan 05, 2021 11:17 am
I just done the wheel bearing replacement and seals and wear collar on my front chunks. All seems good now. question do you have to fill each wheel chunk with 90wt or does it migrate from center where dipstick is ? Next question after all was back together I noticed when going over bumps I hear a grinding from front I think. Only when hitting ruff bumps. Flat ground all seems normal. Any ideas on this noise? All in the wheel gear boxes seemed fine and tight.
Re: jd-950 4whd
Postby winston » Tue Jan 05, 2021 2:29 pm
It migrates but can take a while in doing it. Might want to check it for several days. No idea about the grinding.
Users browsing this forum: No registered users and 29 guests
