790 JD
HLHobby
790 JD
Postby HLHobby » Sun Jul 12, 2020 5:13 am
2004 JD 790 - Was running fine, suddenly quit, found that the neg battery cable fell off. Reconnected, rolls over great but now does not start. Checked fuses, no issues.
Re: 790 JD
Postby Aaron » Fri Jul 17, 2020 11:15 am
Doe the 790 shut off with the key switch or do you have a kill cable that you have to pull?
Re: 790 JD
Postby winston » Fri Jul 17, 2020 2:41 pm
Not sure all models are the same but I believe the 790 does have a fuel shut off solenoid. Might want to check it. This is just one example. https://www.greenpartstore.com/John-Dee ... 06808.html
Users browsing this forum: No registered users and 30 guests
