790 JD
Re: 790 JD
Doe the 790 shut off with the key switch or do you have a kill cable that you have to pull?
Re: 790 JD
Not sure all models are the same but I believe the 790 does have a fuel shut off solenoid. Might want to check it. This is just one example. https://www.greenpartstore.com/John-Dee ... 06808.html
Users browsing this forum: No registered users and 26 guests
