YM2000 REBUILD 2 cylinder Rebuild 2TR20A
nothead14
Postby nothead14 » Thu Jul 04, 2019 8:52 am
After rebuilding,tractor was hard to crank.Adjusted valves every way possible. Tractor is blowing back through intake and smoking. Any ideas why? Thanks Ken
Re: YM2000 REBUILD 2 cylinder Rebuild 2TR20A
Postby winston » Thu Jul 04, 2019 10:53 am
Got .006" clearance on all valves? Did you have the head reworked? Have ;you used starting fluid?
Postby Aaron » Fri Jul 05, 2019 1:33 pm
What was wrong with the tractor before the rebuild?
Did you set the valves like this?
https://www.hoyetractor.com/valve-set.htm
It is not uncommon for those 2cyl Yanmars to puff back out the intake like that when they don't start. I have seen that many times. Once they fired up they all ran just fine.
Users browsing this forum: Google [Bot] and 13 guests
