Yanmar 3810D what type hydraulic fluid
Tutbtaz861
Postby Tutbtaz861 » Sat Sep 29, 2018 8:09 am
I have a Yanmar 3810D 4 wheel drive tractor and am planning to change out the hydraulic fluid, The tractor uses the fluid for transmission and hydraulics. Just want to make sure I use the correct fluid. Thanks for any help.
Re: Yanmar 3810D what type hydraulic fluid
Postby winston » Mon Oct 01, 2018 2:06 pm
https://www.hoyetractor.com/support/kno ... ?article=1
I personally use Tractor Supply's Traveler brand. Very reasonably priced and I believe a good product. https://www.tractorsupply.com/tsc/produ ... luid?rfk=1
bmaverick
Postby bmaverick » Mon Jan 28, 2019 3:59 pm
A Yanmar 3810 has the 3T84 engine series with PowerShift. Thus, look at the tractors next-of-kin in the John Deere family that is Yanmar made. The JD-870 is a close match. Thus, the J20C is the best bet to get in North America.
The JD fluid listing can be found here:
https://jdparts.deere.com/partsmkt/docu ... ipment.pdf
The use Tractor Data to find the closest JD tractor configuration. :)
For a YM2500/YM2610, it's a perfect match up to a JD-850/950. Still, J20C is the the match.
