Confirm rocker arm torque spec?
lobanz
Postby lobanz » Mon Jul 28, 2014 12:12 pm
Service Manual says 40 ft-lbs. Confirmed with Hoye. But this seems a little high for these small studs (http://www.hoyetractor.com/PROD/search/105225-11350.htm). Stripped two already. Is 40 ft-lbs correct? From what I see, M8's are in the 18 ft-lb range.
I have a 1610D (3T75U engine).
--- Lobanz
[Yanmar 1610D w/FEL]
Re: Confirm rocker arm torque spec?
Postby winston » Mon Jul 28, 2014 1:54 pm
I was thinking the large threads are 10mm. Interesting though, page 20-00-2 in the 220/226 manual listing specs show "rocker arm shaft support nuts - 40 ft lbs.
Page 20-05-5 (same manual) showing assembly of rocker arm shaft states 27 ft lbs.
Page 20-05-13 (same manual) showing installation of cylinder head states "Tighten rocker arm support nuts to 40 ft lbs.
There is also a generic torque chart in this manual showing 40 ft lbs should be fine for a 10mm grade 7 bolt.
I know this is confusing and there has to be a mistake somewhere. If they are indeed 10mm I would go with the 40 ft lbs.
lobanz
Postby lobanz » Mon Jul 28, 2014 2:12 pm
winston wrote:[...] I know this is confusing and there has to be a mistake somewhere. If they are indeed 10mm I would go with the 40 ft lbs.
Great. Thanks!
--- Lobanz
jonokimber
Postby jonokimber » Fri Jun 26, 2020 9:58 am
Hi Winston and Lobanz
I just stripped the three original rocker arm nuts on my 1610 engine going for 54 N.m which is 40 ft.lbs
QUESTION - Did you ever find a torque value that didn't strip the nuts?
QUESTION - What grade are these nuts, i just can't make it out?
QUESTION - I can't seem to find M10 x 1.25 6mm thick nuts anywhere, any ideas?
Many thanks.
Jono
Users browsing this forum: No registered users and 4 guests
