Powershift relief valve spring replacement
Have repair or maintenance instructions that you want to share with other Yanmar owners? Post them here.
BRETO
Postby BRETO » Tue Apr 22, 2014 5:21 am
I have just replaced the valve spring in a FX24D. I found the support and expertise on this site that has given me the insight and confidence to tackle this task.
This valve is located next to the right heel. It is in behind a large cir clip. Once you have removed the clip, find a 6mm bolt and screw it into the thread in the center of the access plug. Then pull the plug out using the bolt as leverage and something to hold on to. This is where the spring is housed.
At the other end of this "plug" is another smaller cir clip. Take it out and a small cylinder will come out. The spring is in behind that.
Part number 9
number 194555-24670
Relief valve spring broken into 3 pieces
BRETO
Re: Powershift relief valve spring replacement
Postby BRETO » Tue Apr 22, 2014 5:26 am
Part number and spring
BRETO
Postby BRETO » Tue Apr 22, 2014 5:32 am
This spring worked first time and I hope it keeps going.
I don't have access to parts as it is an import
Spring is 7.5mm diameter, 1mm thick, cut down to 19mm.
BRETO
Postby BRETO » Tue Apr 22, 2014 5:41 am
The original spring measured 17mm. I made it 19 as I thought it had been working.
fx24d spring7.5mmx17mmx1mm.jpg (163.22 KiB) Viewed 2807 times
BRETO
Postby BRETO » Tue Apr 22, 2014 5:43 am
Thanks for your help Winston.
Return to “Tutorials & Instructions”
Users browsing this forum: No registered users and 1 guest
