RSB 1300
Two Cedars
Re: RSB 1300
Postby Two Cedars » Fri May 22, 2020 8:34 am
Aaron and WInston thanks for your help. Upon closer inspection of the schematic there is a #8 plug in both the front and back of the gear box, I will try using the one mounted higher on the case and see if that works.
Users browsing this forum: Google [Bot] and 18 guests
