Splined Coupler stripped
Cwall64
Postby Cwall64 » Sun May 17, 2020 1:24 pm
Thought clutch went out. Split tractor in two found the splined coupler on the transmission side stripped. Clutched looked good.
History:
Hooked up finishing mower with pto running going down a hill I pushed in the clutch to change to a lower gear. The tractor would not go into any gear from that point on. The shift would go into gear, but would not engage. Any ideas why this would strip out the coupler?
Y1500d
Re: Splined Coupler stripped
Postby Aaron » Mon May 18, 2020 11:53 am
They are sort of a wear item. It is a pretty hostile environment where they live. It is not uncommon for them to eventually wear out.
https://www.hoyetractor.com/PROD/SC-2618.htm
Users browsing this forum: Google [Bot] and 16 guests
