186d slow return valve
CGS
Postby CGS » Sat May 16, 2020 10:44 pm
I have a 186d. They hydraulics will go up and down fine. The problem is when I raise my implement it will not hold. It will drop down immediately as soon as I put the lever in neutral. I've tried adjusting the slow return valve with no results. I can either leave lever up or it will lower immediately down. Was working fine before this. Can it be a bad valve? Thanks
Re: 186d slow return valve
Postby Aaron » Mon May 18, 2020 11:51 am
If you close the lock valve with the three point in the up position will it still go down?
https://www.hoyetractor.com/brokenlift.htm
Users browsing this forum: No registered users and 16 guests
