1500 geeen shifter spring
Hardtail31
Postby Hardtail31 » Sat May 16, 2020 8:19 pm
Having trouble installing the shifter back in after having to replace the spring! Does the clip and washer go underneath the shifter plate? Any pics are helpful.
Re: 1500 geeen shifter spring
Postby winston » Sun May 17, 2020 4:33 am
I believe they go above the shifter plate.
Hardtail31
Postby Hardtail31 » Sun May 17, 2020 7:00 am
I’ve looked at that schematic for reference and I can’t get the circling back in the shifter housing
It seams like the spring is bottomed out on the ball on the shifter.
Postby winston » Sun May 17, 2020 7:40 am
Hardtail31
Postby Hardtail31 » Sun May 17, 2020 9:20 am
Exactly how I put everything back on the shifter. It still doesn’t allow me to push the retaining clip back into the housing thet holds the shifter in place
Postby winston » Sun May 17, 2020 2:09 pm
I am old and slow most of the time. This is one of those times. I am not fully understanding. Do you have the new are old style from this drawing. Maybe using reference numbers to explain.
Hardtail31
Postby Hardtail31 » Sun May 17, 2020 6:22 pm
Old style. Original green
Postby winston » Mon May 18, 2020 3:50 am
Maybe shift lever guide (reference 12) is out of position. Have you had shifter cover (reference 28) off? If not, you may have too.
Hardtail31
Postby Hardtail31 » Mon May 18, 2020 3:51 pm
Shifter cover is off. I’ll have to re align it again and see if it will fall into place. But I had been in the right spot.
Hardtail31
Postby Hardtail31 » Mon May 25, 2020 12:13 pm
Got the shifter bit back together and installed. It’s a super tight fit with no movement. The new shifter spring is thicker that the old one! Is it possible that the new style shifter Teflon ball is smaller than the older original one from the solid one piece housing?
Postby winston » Mon May 25, 2020 3:54 pm
That is an Aaron question. :mrgreen:
Hardtail31
Postby Hardtail31 » Mon May 25, 2020 3:57 pm
I figured. Haha. Yeah it’s crazy to me too. I’m at a loss. That’s the this issue is the only think keeping me from using the tractor
Postby Aaron » Tue May 26, 2020 2:10 pm
The spring & ball are the same on both styles. Do you have it all installed like this?
Yours will be the 1 piece setup without the little tower but everything will install the same. Just pretend your tower comes off.
Hardtail31
Postby Hardtail31 » Tue May 26, 2020 7:39 pm
Are the roll pins supposed to sit flush inside the ball?
Postby Aaron » Tue May 26, 2020 8:02 pm
No. The pin extends out both sides to sit in the slot in the shift tower area to keep the handle from spinning.
Users browsing this forum: No registered users and 37 guests
