Break Shoe Raplacement
mbelew@bellsouth.net
Postby mbelew@bellsouth.net » Fri May 08, 2020 11:51 am
Re: YM1500D. The breaker shoe cover has a bolt protruding the cover with nut and washer in addition to the 5 cover bolts and breaker lever. The kit included a gasket with the pattern that matches. What is the protruding bolt holding? Should the nut be remain while removing the cover?
Re: Break Shoe Raplacement
Postby Aaron » Fri May 08, 2020 12:34 pm
The bolt is the end of the adjustment cam.
#5 below
https://www.hoyetractor.com/CTGY/YM1500BRAKES.htm
Users browsing this forum: winston and 15 guests
