YM1500 3 Point lift problem
Rev. Joe
Postby Rev. Joe » Wed May 06, 2020 12:33 pm
Lift stopped working so I changed fluid (replaced w/Warren 303 Tractor Fluid), cleaned filter screen and replaced Hydraulic lift valve located under seat, after about 2 hours of use the lift stopped going up. Any ideas on where to look for the problem would be a big help.
Re: YM1500 3 Point lift problem
Postby Aaron » Thu May 07, 2020 12:14 pm
Does the oil look creamy or foamy when it stops working? It could be sucking air. Eventually it can get so much air in it that it wont work.
Rev. Joe
Postby Rev. Joe » Thu May 07, 2020 1:27 pm
Yes, it did look a little foamy. How wood I go about locating the problem?
Postby winston » Thu May 07, 2020 1:40 pm
If your fluid level is good then air could come in anywhere along the suction line, most likely at rubber boot #14.
Rev. Joe
Postby Rev. Joe » Thu May 07, 2020 5:30 pm
Thanks for the help, I'll check that out.
Users browsing this forum: Majestic-12 [Bot] and 15 guests
