Yanmar 1610D
DARDS
Yanmar 1610D
Postby DARDS » Wed Apr 29, 2020 4:59 am
Can anybody suggest what may have gone wrong?
Yanmar 1610D. Engine runs fine and clutch is good and relays engine drive to coupler in bell housing and turns input shaft (we have split the tractor to check all of this)
However when you view the Hydraulic clutch pack through the gearbox dipstick the drive does not come into the gearbox
Drive has been lost at the very front of the gearbox where the power shift unit is.
Has anybody had the same? Many Thanks
Re: Yanmar 1610D
Postby Aaron » Wed Apr 29, 2020 10:42 am
Does your PTO still turn? It is usually the splined coupler or the splines on the powershift pump input shaft that fails. Sounds like you have eliminated that though so you will probably have to do some more digging to see what is going on. Keep in mind a lot of that stuff will not turn in there unless it is in gear.
