Thermocouple ?
pat55
Thermocouple ?
Postby pat55 » Thu Mar 19, 2020 5:11 pm
I'm not sure if my YM 2210 has a thermocoupler for preheat prior to start up, the parts list says " optional" and there is no label at the ignition switch,but the switch does turn to the left like it is set up for it and the warning lights also come on when it turns left. I guess I'm not sure what one looks like or where it would be located. Anyone have any idea .
Re: Thermocouple ?
Postby Aaron » Thu Mar 19, 2020 5:16 pm
The thermostart is located in the intake manifold. You will either have a thermostart with a wire and hose going to it or you will have a plug.
pat55
Re: Thermocouple ?
Postby pat55 » Thu Mar 19, 2020 5:29 pm
Thank you for the correct terminology, I will see if I can locate the wire or plug.
Re: Thermocouple ?
Postby winston » Fri Mar 20, 2020 5:33 am
Users browsing this forum: pat55 and 18 guests
