ym1510d pump timing procedure
fixer
Postby fixer » Thu Mar 19, 2020 4:07 pm
I have tried to check the timing on my 1510d as per manual and hoye online procedure but do not get any fuel from pump. system has been bled engine smokes but will not start. previous mechanic installed new pump so I don't know how he shimmed it.
Re: ym1510d pump timing procedure
Postby Aaron » Thu Mar 19, 2020 5:22 pm
If you are not getting any fuel out of the injection pump then shimming will not help (unless there was a ridiculous amount of shims installed). Also if you are not getting any fuel out of the pump then it should not smoke either. Are you not getting any fuel out of any of the cylinders on the pump? Is the throttle in the full throttle position? Is the governor hooked up for sure? What happened to the original pump?
https://www.hoyetractor.com/support/kno ... article=12
