YM2000 Quick Hitch
johnyarb
YM2000 Quick Hitch
Postby johnyarb » Fri Mar 13, 2020 10:53 am
Hey Aaron,
Wondering if you might know if one of the Harbor Freight (or any other) quick hitches will work with a YM2000 lift? Looks like i would for sure need a hitch adapter and possibly bushings? Any info you have would be great.
Thanks for the help,
JY
Re: YM2000 Quick Hitch
Postby winston » Sun Mar 15, 2020 5:59 am
Butting in as usual. The pin size will be correct. Here is the Harbor Freight on my old 2002D which I now use on a Bobcat CT235. It will work on any category 1 tractor. Notice the Adapter I made where the top link attaches. I found that very necessary. I can also tell you that many category 1 implements will not work without rework. There is quite a variation on pin width, sometimes your can turn the lift pins around on implements but sometimes even that won't work. If I had it to do over I would buy Pats quick hitch or similar. https://www.ruralking.com/pats-easy-cha ... A-EALw_wcB
