Head stud
jimjumper
Head stud
Postby jimjumper » Sun Mar 08, 2020 8:55 pm
Slowly working through a piston and ring job on a 240D. Removed the head today and instead of the nut unscrewing from the stud, the whole stud and nut came out from the block. Anything special to just screwing it back in with 2 stacked nuts and then torquing down the head nut when I do the head gasket? And are the threads the same for either end of the stud?
Re: Head stud
Postby Aaron » Mon Mar 09, 2020 11:44 am
That is not uncommon. Just screw it back in and you should be good to go. Threads are the same on both ends.
Users browsing this forum: No registered users and 19 guests
