Fuel tank repair
Threeweight
Fuel tank repair
Postby Threeweight » Wed Jan 22, 2020 2:49 pm
My Yanmar 1500D has a small triangular chunk missing from the top of the filler neck on the fuel tank, roughly 1/8" tall by 1/8" wide. Not huge, but big enough that if I fill the tank above half full and/or operate the tractor on rough ground I will get some fuel sloshing out, and end up with dust and gunk stuck to the tractor below it.
Anyone know if there is a plastic patch product that will stick to the plastic on the original (circa 1978) tank? Other than this tiny notch, the tank is in decent shape and works fine.
Re: Fuel tank repair
Postby winston » Wed Jan 22, 2020 3:35 pm
There are numerous ways to repair plastic. Welding is one of them I have successfully used. Different ways to approach it. If my attach doesn't work just go to youtube and search fuel tank repair. https://www.youtube.com/results?search_ ... nk+repair+
Postby Aaron » Thu Jan 23, 2020 3:09 pm
Yup, I have welded up all sorts of plastic stuff over the years. I just use a regular soldering iron but I see Harbor Freight even sells an inexpensive plastics welder.
https://www.harborfreight.com/80-watt-i ... 60662.html
