3110 D External Hydrailic pump drive gear
wethomas
Postby wethomas » Wed Jan 22, 2020 11:13 am
Can you tell me the torque value for the bolt that retains the drive gear for the external hydraulic pump. This gear is located on the front of the engine and meshes with the cam drive gear. Not to be confused with the transmission hydraulic pump drive assembly.
I can not find it in the shop manual. The bolt bears the #7 headstamp and according th the torque chart in the manual (specific to fastener stamp / diameter/ type ) it lists the value at 50 ft/lb. Im skeptical of this however. Seems to me it might be more, given the nature of the gear design.
Re: 3110 D External Hydrailic pump drive gear
Postby winston » Wed Jan 22, 2020 11:48 am
Are we talking about #32 here?
Might look at this chart. https://www.tractorbynet.com/forums/fil ... -chart-jpg
wethomas
Postby wethomas » Tue Jan 28, 2020 5:59 am
Thanks very much for the work you guys do on this site.
