FX22D no charge when regulator is grounded
Glitch
Postby Glitch » Fri Jan 17, 2020 7:12 pm
like the topic says if I unground the regulator i get 13.7 Volts at the battery If I ground it the light come on and the volts at the battery bounces 11.2 and 12.3 volts. does this mean regulator is bad? or a short to ground some were? does it need to be grounded? everything works fine i am just not used to a generator type alternator. any one have a line on a FX22D repair manual?
Re: FX22D no charge when regulator is grounded
Postby winston » Mon Jan 20, 2020 3:38 pm
Does the normal mounting make it appear the regulator is suppose to be grounded?
Glitch
Postby Glitch » Mon Mar 02, 2020 1:50 am
well this is were it becomes a grey area. im not sure, but after further review if it touches metal at all it goes into a no charge.
Postby winston » Mon Mar 02, 2020 6:18 am
This is over my head. I does sound like you could run with it ungrounded and be ok. However, I doubt it was designed to be that way.
Users browsing this forum: No registered users and 41 guests
