Air in fuel line?
dc714
Air in fuel line?
Postby dc714 » Sun Jul 07, 2019 5:43 pm
I've got a 198? F165D. I changed the fuel filter and didn't bleed the air before I restarted and ran the engine. Would that cause the tractor to run but lose power and die intermittently especially under load? If not, what else could I check?
Also, I cannot find any bleeder screws on this tractor, neither at the filter or near the injectors. Any ideas where they are?
Thanks.
Re: Air in fuel line?
Postby Aaron » Mon Jul 08, 2019 11:59 am
That is most likely caused by a bad fuel feed pump. You can test it by unhooking the hose and pumping manually using the little lever.
https://www.hoyetractor.com/PROD/129158-52100.htm
dc714
Postby dc714 » Wed Jul 10, 2019 11:52 am
Thank you. I'll try that.
dc714
Postby dc714 » Tue Jul 16, 2019 1:33 pm
I got the pump. I can't get the old pump off. It is held on by two nuts. I can't get a wrench or anything around the upper nut because there isn't enough clearance between the nut and the pump. Has anyone had this issue and found a solution? I'd appreciate any advice. Thanks.
Postby Aaron » Tue Jul 16, 2019 1:39 pm
You might need something like this (only not 3/4" :) )
dc714
Postby dc714 » Tue Jul 16, 2019 1:44 pm
Thanks Aaron, but I can't see the picture.
Postby Aaron » Tue Jul 16, 2019 1:46 pm
dc714
Postby dc714 » Tue Jul 16, 2019 10:35 pm
Thanks Aaron. I managed to get it off using vise grips and a lot of patience. It was not easy. The new one is on.
One more question, I drained the gas from the engine. Do I need to do anything after I refill the tank before starting it up?
Thanks for all your help.
Dennis
Postby Aaron » Wed Jul 17, 2019 7:45 am
You will want to bleed the air out of the system using the hand pump on the pump you just installed.
dc714
Postby dc714 » Wed Jul 17, 2019 12:07 pm
Do you know where the bleeder screws are on the 165? There aren't any on the fuel filter housing as I've seen in "how to" videos.
Users browsing this forum: No registered users and 19 guests
