Ball bearings on 4x4 axle shaft
beartrace
Postby beartrace » Sat Jun 29, 2019 3:08 pm
Doing engine R&R. When separating the ball bearings in the forward 4x4 shaft fell out. How and where do I reinstall? Can I install the engine then later install the 4x4 shaft?
Thank you in advance.
Re: Ball bearings on 4x4 axle shaft
Postby Aaron » Sat Jun 29, 2019 5:45 pm
The 6 little balls on each end are #34 in the link below
https://www.hoyetractor.com/CTGY/16104WDINT.htm
Yes you can re-install that shaft after everything else is back together.
Use grease to hold the balls in place while you re-install.
beartrace
Postby beartrace » Sat Jun 29, 2019 6:41 pm
Ok, thanks, but I am still uncertain where they go.....
Postby winston » Sun Jun 30, 2019 5:30 am
Users browsing this forum: Bing [Bot], winston and 26 guests
