YM165D tachometer/hourmeter ratios
mctank
Postby mctank » Thu Jun 13, 2019 7:38 am
I am currently having Nichols Instruments in Greensboro, NC repair the tach/hourmeter from my YM165D. They have requested the cable and hourmeter ratios. It is a Nippon Seiki mechanical instrument. Appreciate any assistance you can provide.
Re: YM165D tachometer/hourmeter ratios
Postby winston » Thu Jun 13, 2019 12:07 pm
Wow, good luck with that. :shock:
Postby Aaron » Thu Jun 13, 2019 2:02 pm
I have never seen that anywhere but you should be able to just turn your engine over (by hand) X times and see how many times the cable turns.
mctank
Postby mctank » Thu Jun 13, 2019 3:35 pm
Agree...that takes care of tach.
Postby winston » Thu Jun 13, 2019 5:38 pm
That would give you the engine to tach cable ratio which I guess is what you are really wanting.
mctank
Postby mctank » Sat Jun 15, 2019 8:44 am
I also need hourmeter ratio.
Postby winston » Sat Jun 15, 2019 10:43 am
mctank wrote:I also need hourmeter ratio.
Back to my first statement, good luck with that, I'll be surprised if you can come up with it. I am supposing that would be how many turns per second? at 2000rpm or something along those lines.
PatrickHanna
Postby PatrickHanna » Mon Jun 17, 2019 7:54 am
My hour meter says that 6 minutes at 2400 RPM is equal to 1/10 of an hour. That's 40 revolutions per second for the hours meter to record in real time, or 14,400 revolutions for every 1/10 increment.
Users browsing this forum: No registered users and 22 guests
