1401 rear axle seal
Re: 1401 rear axle seal
Postby winston » Wed Jul 31, 2019 5:19 am
Little to far for me. No doubt, they are missing something. I wish you the best of luck and keep us posted.
dagnblond
Postby dagnblond » Wed Jul 31, 2019 3:36 pm
tractor is home now hoping to be able to pull it apart Sunday if weather cooperates . does anyone know what the axle diameter is supposed to be ? I plan to put straight edge and micrometer on it
Postby winston » Wed Jul 31, 2019 4:25 pm
I am not certain. My research shows there could be one of two sizes. Either a 45-70-12 seal or a 50-70-10 seal. shaft size should be either 45mm (1.772") or 50mm (1.969"). If you can use the micrometer on it you should be able to know which. Don't try to borrow any money on what I am saying, hopefully something to get you pointed in the right direction.
dagnblond
Postby dagnblond » Sun Aug 04, 2019 11:08 am
My micrometer shows 44.87 mm
I don't know how to add pics
Postby winston » Sun Aug 04, 2019 11:52 am
Hmmmmmm, sure sounds like the shaft is undersized. That would be about .005" undersized. Any signs of grinding on it?
If you click on the Attachements box below, then just follow directions, you should be able to load pictures.
dagnblond
Postby dagnblond » Sun Aug 04, 2019 12:13 pm
dagnblond
Postby dagnblond » Sun Aug 04, 2019 12:16 pm
kinda looks like seal wasn't installed properly
Postby winston » Sun Aug 04, 2019 12:28 pm
Might be hard to do but have you tried using your caliper to measure the inside diameter of the seal. Also how is the fit when the shaft slides through the seal? Is there a number on the seal?
dagnblond
Postby dagnblond » Sun Aug 04, 2019 12:35 pm
hard to tell how it slides thru the seal till I get another one as it contacts the outer bearing pretty much at the same time and has to be pressed into the bearing
dagnblond
Postby dagnblond » Sun Aug 04, 2019 12:37 pm
but if it's supposed to be 45 mm then it is definitely under sized as this measures 44.87 mm
Postby winston » Sun Aug 04, 2019 12:54 pm
Maybe try a 44x70-12 seal. Just throwing ideas out there. Any number on your seal??
dagnblond
Postby dagnblond » Sun Aug 04, 2019 1:13 pm
Don't see one on seal itself but Hoye number is AS-1300
Postby winston » Sun Aug 04, 2019 2:23 pm
The 135/155 parts manual showns a TC45-70-12. Hoyes shows their seal fitting the 135, 155, 1300 and 1401 and maybe others.
dagnblond
Postby dagnblond » Mon Aug 05, 2019 4:20 pm
gonna try to go up to Jacksonville this week and see if Miller Bearing can match up a seal that will work
dagnblond
Postby dagnblond » Fri Aug 30, 2019 3:17 pm
Finally fixed , it turns out the JD shop ground on the axle and it's a little out of round even though they claim all they used was steel wool. Anyway the measurements are off so went with the smaller of measurements and got a 44×70×8 seal and it's working. Would have been nice if their highly trained tech or his service manager could read a micrometer this could have been fixed 2 months and a few hundred dollars ago
Users browsing this forum: Google [Bot] and 20 guests
