1401 rear axle seal
dagnblond
1401 rear axle seal
Postby dagnblond » Sat May 18, 2019 1:47 pm
1 of my rear axle seals is leaking and I contacted Hoye and was told all I need was seals and gasket for the top
I can't get the axle out even after removing the side housing the axle and removing the 2 bolts on end of axle and yes wheels and hubs are off any hints here or are the bearings pressed onto the axle
Re: 1401 rear axle seal
Postby winston » Sun May 19, 2019 12:07 pm
Not sure I am understanding. I am thinking you have removed side housing with gear and bearing exposed. Assuming you have removed the end retainers (21,22,23) then yes, you might need a puller to remove bearing and gear.
dagnblond
Postby dagnblond » Sun May 19, 2019 11:30 pm
yes I removed the side housing and in looking between gear and housing I noticed the reason for the seal failure is the outer bearing went bad
Postby Norm » Mon May 20, 2019 7:56 am
Aren't the seal and bearing both in the side cover, or are both bearings bad?
dagnblond
Postby dagnblond » Mon May 20, 2019 8:58 am
the seal is in the housing but it appears that the axle will have to be removed before the seal can be removed and replaced and bearing seems pressed on and I can't find anywhere close to here that can press the old off and new on
dagnblond
Postby dagnblond » Mon May 20, 2019 9:03 am
the axle in the video looks nothing like mine I have a pic but don't know how to post it on here
Postby winston » Mon May 20, 2019 9:39 am
dagnblond
Postby dagnblond » Mon May 20, 2019 10:40 am
yes the one in the video is the one I was talking about not looking like mine
