Yanmar YM2000 Coolant Drain Plug Location
johnyarb
Postby johnyarb » Thu May 16, 2019 2:30 pm
Hi Guys,
Complete newbie here. I just purchased a 1977 Yanmar YM2000 and for the life of me can't find where the coolant drains from the radiator. I need to flush the cooling system....Hopefully someone can help!
Thanks much,
John
Re: Yanmar YM2000 Coolant Drain Plug Location
Postby winston » Fri May 17, 2019 5:31 am
johnyarb
Postby johnyarb » Fri May 17, 2019 8:44 am
Thanks for the reply. I'm still not able to locate even after looking at the diagram. Is it possible the drain hole could be plugged?
johnyarb
Postby johnyarb » Fri May 17, 2019 10:09 am
Here's a picture for reference. Shouldn't it be in the area of the white circles?
Postby winston » Fri May 17, 2019 11:27 am
On the other side of the radiator.
Postby Norm » Fri May 17, 2019 1:03 pm
It probably does'n't have one. you drain the block or lower rad hose, at least on my YM2000B.
johnyarb
Postby johnyarb » Mon May 20, 2019 3:10 pm
Yes that is what i was thinking. There's no drain plug. Only way to do it is remove lower radiator hose. Thanks.
Users browsing this forum: No registered users and 21 guests
