ym2210d no indicator lights
stargc
Postby stargc » Thu May 09, 2019 7:22 am
I have no indicator lights,no horn or head lights,fuses are good and starts up no problem any suggestions on problem or what to check. thanks.
Re: ym2210d no indicator lights
Postby Aaron » Fri May 10, 2019 8:31 am
There is one wire that goes from the ignition switch's on position to the fuse box that powers all of the things that are not working. My guess is that wire has a bad connection somewhere or that part of the ignition switch is bad.
Users browsing this forum: Bing [Bot] and 19 guests
