front axle bearings
mrubycomo
front axle bearings
Postby mrubycomo » Sat May 04, 2019 11:41 am
I bought new bearings for the drop box on the 3810d and the ones I received are sealed bearings the ones I removed are not. Do I need to remove the seals in order to get proper lubrication to the bearings?
Re: front axle bearings
Postby winston » Sat May 04, 2019 4:32 pm
Your title reads front axle bearings but you are saying drop box. Not sure which bearings you are talking about. If it is the drop box I would remove the seals. those bearings are covered in fluid.
Postby Norm » Sun May 05, 2019 4:20 pm
I would first check with the supplier to assure you have the correct bearings.
Postby winston » Mon May 06, 2019 5:19 am
I know from my work experience that some company's stock sealed bearings and not open bearings just to same on inventory space. Seals are easily popped out. Probably a good idea to check with the supplier anyway.
Postby Aaron » Mon May 06, 2019 11:20 am
All of our bearings come sealed now for that reason. If you are replacing an open bearing you just pop out the little plastic seal. It just snaps in.
Postby Norm » Mon May 06, 2019 11:34 am
Good to know, new one on me . . Have never run into that issue. :) :)
