Tilt on bucket not working
CapnJck
Postby CapnJck » Fri Apr 19, 2019 11:00 am
YM2210d....tilt on bucket quit working
Re: Tilt on bucket not working
Postby winston » Sun Apr 21, 2019 5:24 pm
Could be loader control valve or could be blown seal in a cylinder just letting fluid pass through.
Might consider changing lift and curl hoses on loader valve to confirm whether in valve or cylinders. However, if you are able to move the bucket back and forth by hand I would say a curl cylinder is bad.
What brand loader and valve?
Users browsing this forum: Google [Bot] and 19 guests
