1720d questions
Bnkrbill
1720d questions
Postby Bnkrbill » Wed Apr 03, 2019 12:56 pm
I just bought a 1720d tractor. It has some mechanical issues. Can someone tell me basically how the transmission on this model works? It has a lever that you move left and right with a side gauge. This tractor does not want to go into gear. It appears that it will move forwWhen it is in four-wheel-drive or the differential lock is pressed. Any ideas? None of the hydraulics or working. Could this be related? Is there a hydraulic screen in the transmission somewhere that could be clogged?
Re: 1720d questions
Postby Norm » Wed Apr 03, 2019 4:39 pm
"It appears that it will move forwWhen it is in four-wheel-drive or the differential lock is pressed. " What do you mean by "it appears"? If it will move with diff locked check for broken brake stub axle, (pinion), either side.
