Yanmar YM14 Powershift Problem
Re: Yanmar YM14 Powershift Problem
Postby Norm » Thu Mar 28, 2019 8:43 am
Are you saying you found nothing after inspecting the shift yoke mechanism?
https://catexcavatorservicerepairmanual ... ts-manual/
Yanmar918
Postby Yanmar918 » Thu Mar 28, 2019 12:00 pm
I had similar issue. Put in neutral I removed the front /Top shifter cover where the two forks are I drained the hydraulic fluid down far enough that I could see the two bearings that the forks straddle. Put in neutral before you start slowly make lower cover making sure the forks are where they go . (Straddling the two Bearings) then replace fluid
