Am I running too cool?
gwp
Postby gwp » Tue Mar 19, 2019 5:51 pm
YM2000
Even under a moderate load I can't get engine temp over 130 degrees as measured with new temp gauge. Is that ok? New radiator, water pump, hoses, etc. I hope it's ok as without a thermostat, there's no way to make it run hotter. Thanks
Re: Am I running too cool?
Postby Norm » Tue Mar 19, 2019 7:03 pm
If correct, and it bothers you, you can always partially block the radiator airflow.
Postby winston » Wed Mar 20, 2019 3:33 am
I would want to check the temperature gauge. Just sounds awfully low to me.
https://www.harborfreight.com/infrared- ... 93984.html
