No reverse in my 1510d even after fluid change
fwalton
Postby fwalton » Sat Mar 16, 2019 6:34 pm
Not sure if I should have started a new thread or added to my old one, I changed the fluid and cleaned the screen in my tractor hoping to fix this problem, which is no reverse at all. It started out as an off and on problem, but now it will never go into reverse, the forward gears work fine. It's the power shift transmission. Any ideas or suggestions will be greatly appreciated.
Re: No reverse in my 1510d even after fluid change
Postby winston » Sat Mar 16, 2019 7:46 pm
Assuming nothing wrong with your shifting linkage then I would suspect the main relief valve. Taking this idea out of a 226 service manual trouble shooting section. Might check the spring and for trash.
fwalton
Postby fwalton » Sat Mar 16, 2019 8:42 pm
winston wrote:Assuming nothing wrong with your shifting linkage then I would suspect the main relief valve. Taking this idea out of a 226 service manual trouble shooting section. Might check the spring and for trash.
Is the shifting linkage all external, or do I have to remove something to see it? Is there a diagram or photo?
Postby winston » Sun Mar 17, 2019 6:13 am
fwalton
Postby fwalton » Sun Mar 17, 2019 9:03 am
winston wrote:https://www.hoyetractor.com/CTGY/YM1510POWERSHIFTCONT.htm
Thanks!
fwalton
Postby fwalton » Sun Mar 17, 2019 11:42 am
Is there a parts list that goes with the numbers on this diagram? They are not all listed on the hoye tractor website.
Postby winston » Sun Mar 17, 2019 2:06 pm
fwalton
Postby fwalton » Sat Mar 23, 2019 1:11 pm
Just wanted to let everyone know, it was a worn gear shift lever, to much play and not enough room in the slot in the cover.
Users browsing this forum: No registered users and 24 guests
