New battery, clean terminals on both ends- no turn over
agirlandhertractor
Re: New battery, clean terminals on both ends- no turn over
Postby agirlandhertractor » Wed Apr 03, 2019 3:23 pm
Fixed.
Pulled apart every connector and cleaned. Also upgraded the following:
Positive and negative battery cables (both 1/0 AWG)
New alternator
New regulator
Intended to swap keyswitch but the new one had screw connectors that were larger than the wiring eyelets on the yanmar, so I'll tackle that later.
Users browsing this forum: No registered users and 27 guests
