Yanmar 2001D 4X4
Yanmar918
Re: Yanmar 2001D 4X4
Postby Yanmar918 » Sat Apr 27, 2019 12:10 pm
I installed new regulator still showing 11.6 volts ??
I did check dynamo and getting juice out of it
any advice on getting it to put volts to the battery
If I turn it off usually it has very low turnover
Postby winston » Sat Apr 27, 2019 5:54 pm
What ac voltage were you showing at your dynamo?
I am unsure just what you have had apart on your hydraulics. Sounds like you may have had the relief valve out at the loader valve. Not sure but if so wondering if you have it set correctly. Your stop valve should only be closed when you want to lock the 3 point in a certain position. You do not want to try raising the 3 point when the stop valve is closed.
Yanmar918
Postby Yanmar918 » Sat Apr 27, 2019 8:50 pm
Can you give me some advice on I installed the new regulator but I’m still not showing any more than about 11.6 V
I tested the dynamo and it has power
Postby winston » Sun Apr 28, 2019 4:16 am
What did your dynamo show and at what rpm??
Yanmar918
Postby Yanmar918 » Sun Apr 28, 2019 4:22 am
I didn’t take note of it. I just saw it was rising and falling with rpms. I can get numbers today
That new regulator plugged right in but still only 11.6 v at battery
Postby winston » Sun Apr 28, 2019 4:33 am
"If" your dynamo is putting out a minimum of 13ac volts at idle and considerably more at high rpm they is is good. If not, it is bad.
Have your checked all your fuses?
Yanmar918
Postby Yanmar918 » Sun Apr 28, 2019 4:55 am
I was reading around and saw that a Datsun 510 alternator could convert it over to internally regulated
Have you any experience with this?
Postby winston » Sun Apr 28, 2019 5:04 am
Don't know about The Datsun 510 but I did change out my dynamo for an alternator on my old 2002D. Here is the thread about it. https://www.tractorbynet.com/forums/yan ... ility.html
Yanmar918
Postby Yanmar918 » Mon Apr 29, 2019 1:03 pm
If I was to check dynamo and rpm I have a swell/tach meter where would I attach tach meter
Postby winston » Mon Apr 29, 2019 1:43 pm
Don't know why you would need it. What kind of tach meter do you have? Does it read off a magnetic strip? Sort of guessing it may be for gasoline engine.
Just get a volt reading at idle, open her up and take another reading.
Yanmar918
Postby Yanmar918 » Mon Apr 29, 2019 2:03 pm
Ok will do. I have a friend at work that has a
3920 Farmtrak front loader for sale I have a YM 2000 D
How interchangeable would these be or could be a nightmare
Postby winston » Tue Apr 30, 2019 4:20 am
I can't answer that. If it came off a similar size tractor I'm sure it could be made to work but I would be pretty confident the mounting brackets would likely have to be modified or made over. Do you own both a 2002D and a 2000D?
