Yanmar 2001D 4X4
Re: Yanmar 2001D 4X4
Postby winston » Sun Apr 07, 2019 4:31 am
Yanmar918 wrote:It was the pin type. Now that I have found the broken shaft and know what’s wrong with it can we expedite getting the shaft I want to order everything at once to save on shipping
You need to contact the Hoye parts people with your request.
Yanmar918
Postby Yanmar918 » Sun Apr 14, 2019 12:20 pm
What hydrologic fluid do I need in the case ? I’m not sure what is correct is it hydo fluids or like a 90 weight gear oil
Postby winston » Sun Apr 14, 2019 12:40 pm
Transmission/hydraulic oil such as Tractor Supply Traveler brand or Walmart Supertech. https://www.walmart.com/ip/Super-Tech-H ... JAEALw_wcB
https://www.tractorsupply.com/tsc/produ ... ulic-fluid
Yanmar918
Postby Yanmar918 » Sun Apr 14, 2019 12:58 pm
What’s the capacity all 5 gallons the new dip stick is about 1” longer than the one I found in the bottom of the case. I’ll have to return it probably
Postby winston » Mon Apr 15, 2019 5:18 am
Yanmar918 wrote:What’s the capacity all 5 gallons the new dip stick is about 1” longer than the one I found in the bottom of the case. I’ll have to return it probably
I do not have that information but do have information stating the 2000D capacity is 16 qts.
Yanmar918
Postby Yanmar918 » Sun Apr 21, 2019 5:19 pm
I finally got it working I got the brushhog 98% of my land thanks again for all your help
Yanmar918
Postby Yanmar918 » Tue Apr 23, 2019 5:57 pm
I was wondering why my new battery was going dead apparently the voltage regulator is bad buy it’s attached to another little box Kinda looks like brain box has a part number 2922001 any ideas on parts
Postby winston » Wed Apr 24, 2019 5:57 am
Cetainly can't know but you might read this as a possible little box: https://www.hoyetractor.com/PROD/VR-522.htm
My old 2002D had a little box by the regulator that was the thermostart control. Attached a picture. Maybe you can determine what you have.
Have you checked your dynamo for ac output?
Yanmar918
Postby Yanmar918 » Wed Apr 24, 2019 6:06 am
I haven’t checked it I did check at battery and not even 9 volts . My two boxes are wired together as one. Am I going to have splice new box into the other? From what I can see your pic looks to be two separate pieces
Postby winston » Wed Apr 24, 2019 7:13 am
Sounds like you have the old style regulator spoken of in the regulator I attached last post. If you put your volt meter on ac, touch the leads to the two wires coming out of the dynamo you should be reading ac It will vary depending on engine speed. https://www.hoyetractor.com/support/kno ... ?article=9
Postby Aaron » Wed Apr 24, 2019 1:13 pm
This is the picture that you sent us. I've never seen that before but it is not factory. You will just replace all of that with the regulator that you get from us.... assuming that nothing else in the system has been modified and that it is still using the factory dynamo. Do not splice that extra piece back in.
Yanmar918
Postby Yanmar918 » Fri Apr 26, 2019 11:12 am
Got it ordered and on the way. I’m having a problem getting the bucket to go up and down it’s down now and won’t come back up . I know the screen is clean in lower trans,
I was researching about a stop valve Any advice on where a valve is or where I might start looking. Thanks
Yanmar918
Postby Yanmar918 » Fri Apr 26, 2019 3:34 pm
Do ya think the pump is bad. Not sure why all a sudden it would go out. Maybe a clogged line somewhere??
Postby winston » Fri Apr 26, 2019 4:59 pm
The stop valve is just under your seat right in the middle. Does your 3 point work?
Yanmar918
Postby Yanmar918 » Sat Apr 27, 2019 6:29 am
Ok. I have been messing with that valve using the box blade to keep it in one height . Both front loader and 3 point are acting up . It just started in the last few days after about 10 minutes. The 3 point seems to work for longer or all the time using it but seems like when I start using the front loader the system starts to fail It will slowly start to slow down going in all directions. I did catch myself having the stop valve still closed and trying to work it I opened it up and it started working. So now I make sure it’s always open while using hydrologic stuff and only lock with valve when needed. I took the two Round caps up by the control lever they looked like valve springs in there I cleaned all that up it wasn’t too dirty
I also took a part up by the control lever another round piece and cleaned it out just to make sure it was clean some kind of valve . I’m just trying to check all the small things till I hopefully don’t have to take the pump off
