Yanmar 2001D 4X4
Re: Yanmar 2001D 4X4
Postby Aaron » Fri Mar 22, 2019 10:16 am
Yes, it would really be nice to know what all the previous owner changed and why. Did you ever check the clutch disc to be sure it was installed correctly?
Yanmar918
Postby Yanmar918 » Wed Mar 27, 2019 1:24 pm
Could you send me a picture of which wires go where on the fuse block I had disconnected and lost my notes
Yanmar918
Postby Yanmar918 » Thu Mar 28, 2019 8:08 am
I FOUND A PIC THAT I TOOK WHILE I DISSASEMBLED
FYI>> I PUT THE TRACTOR BACK TOGETHER NOT SURE WHAT CHANGED BUT I THINK I HAVE CLUTCH NOW!!!!! IVE BEEN FINISHING PUTTING IT BACK TUESDAY AND WEDNESDAY I WILL KNOW TONIGHT IF ALL IS GOOD OR NOT I WANT TO THANK YALL FOR PUTTING UP WITH ALL MY QUESTIONS YOUR CUSTOMER SERVICE IS SECOND TO NONE !!
Yanmar918
Postby Yanmar918 » Thu Mar 28, 2019 7:21 pm
I got it back together and move but it only would go forward I have to press the diff lever by my right foot if I put in gear let out on the clutch it dosnt move ?? Only the right wheel turns
I do not have the 4X4 shaft in would that cause it ??
The clutch engages I have to turn idle down so it dosnt grind gears
Postby winston » Fri Mar 29, 2019 5:04 am
Not sure I am understanding. Are you saying the tractor will not move until you engage the differential lock? And then only the right wheel turns? Is it jacked up or how do you know only the right wheel turns?
Yanmar918
Postby Yanmar918 » Fri Mar 29, 2019 5:08 am
Yes only moves when I press down on diff lock I know because I got stuck in the mud. It’s not jacked up I would think I should be able to put it in gear and let out the clutch and it should move I have to turn the idle way down to get it in the gear if it’s up at all it grinds real bad. I’ve got the clutch adjusted so far that the arm taps on the bell housing so I don’t have any more adjustment into the clutch
Postby winston » Fri Mar 29, 2019 5:46 am
Still not completely sure I am understanding but if only the right hand wheel will turn when lock is down then it sounds like your left hand pinion shaft (stub axle) is broken.
Evidently something still wrong in your clutch, however, I am unable to advise from here.
Postby Aaron » Fri Mar 29, 2019 8:46 am
I'm a little confused on exactly what all is going on also but, yes I agree- sounds like the stub axle is broken (fairly common if the diff lock is engaged while one wheel is spinning).
The clutch problem is going to be tough to help on without being there. Since it came to you that way we just don't know what all was changed before. I will say that I don't see any way the original clutch could have worked since the pressure plate fingers are inverted and the hub of the clutch disc appears to protrude beyond the fingers (aka - the release bearing would hit the clutch hub before pushing the fingers). So what happened or what was changed to cause that might explain your current clutch problems. I'm assuming your picture below was taken before you did anything to it?
Did it look like anyone had been in there before? Did it look like the flywheel could have been turned to clean up some wear or damage?
Yanmar918
Postby Yanmar918 » Fri Mar 29, 2019 1:01 pm
I Have it back together just when I put it in gear and let out the clutch doesn’t go anywhere if I turn the idle way down and step on the lever by my right foot it will go
Postby Aaron » Fri Mar 29, 2019 1:11 pm
That is most likely a broken brake stub shaft
This sounds like there is still a clutch problem.
Yanmar918
Postby Yanmar918 » Tue Apr 02, 2019 6:05 am
So when I bought this tractor the brakes were so corroded in water damage from a leaking gasket that they were locked up so we had to drag it forcibly onto the trailer I think during that we probably broke something
Maybe if I open it up and see if that is broke that I will behave differently because I think the one that is broken is the main drive wheel and the other one is for when you lock the diff Hopefully the parts won’t cost too much
Yanmar918
Postby Yanmar918 » Tue Apr 02, 2019 6:09 am
Do you all sell brake stub shaft for the left-hand side
Postby Aaron » Tue Apr 02, 2019 8:07 am
I replied to your support ticket
Yanmar918
Postby Yanmar918 » Tue Apr 02, 2019 8:15 am
Will you update the email for me I think that’s why I’m not seeing them ( I changed it ) ericntulsa2014@gmail.com
Yanmar918
Postby Yanmar918 » Tue Apr 02, 2019 8:04 pm
I tore down the diff the video is at yanmar918 on YouTube
