Yanmar 2001D 4X4
Yanmar918
Re: Yanmar 2001D 4X4
Postby Yanmar918 » Tue Feb 26, 2019 12:01 pm
I’m going to break apart so what I need to look for is the long spline on clutch faces towards the rear. What else do I need to check maybe make sure that the clutch shaft is going all the way into the bushing in the back of the crank
Is not damaged and the shaft is going into it
Postby winston » Tue Feb 26, 2019 3:47 pm
Did you change the throw out bearing? If so, make sure it is on in the right direction. I think your shaft is in correctly just because of the back and forth movement that can be seen on your video.
Yanmar918
Postby Yanmar918 » Tue Feb 26, 2019 4:19 pm
I’m going to break it apart what do I need to look for? Clutch spline long side facing to the rear?
Postby winston » Tue Feb 26, 2019 5:52 pm
Yanmar918 wrote:I’m going to break it apart what do I need to look for? Clutch spline long side facing to the rear?
Yes, and above post.
Yanmar918
Postby Yanmar918 » Wed Feb 27, 2019 9:24 am
Yes pilot bushing clutch and plate TO bearing
Wish me luck
Postby winston » Wed Feb 27, 2019 3:02 pm
If you don't find something that looks wrong when your opened up then take some pictures and post.
Yanmar918
Postby Yanmar918 » Tue Mar 05, 2019 11:10 am
I haven’t broke it apart yet but I was talking to people about it. Could it be I have the wrong pressure plate “not deep enough “
The fingers are not reaching the TO bearing to disengage clutch.
Yanmar918
Postby Yanmar918 » Tue Mar 19, 2019 8:05 pm
OK guys I broke it in half so I put a video on YouTube under Yanmar918 video of the pressure plate shown you what it looks like so take a look at the video and give me some feedback and again thanks
Postby winston » Wed Mar 20, 2019 3:28 am
Not sure what difference it would make but looks to me the throw out bearing is installed backwards. Maybe Aaron will comment.
Attaching your video here. https://www.youtube.com/watch?v=a7UdK3IAxuI
Yanmar918
Postby Yanmar918 » Wed Mar 20, 2019 12:43 pm
I don't think it is I watched video all the way doing it Even if it was still wouldn't solve the issue with it not touching the pressure plate
I emailed a picture to the contact us email hopefully the plate fingers are at more of a angle they have are different
Postby winston » Thu Mar 21, 2019 4:34 am
Yanmar918 wrote:I don't think it is I watched video all the way doing it Even if it was still wouldn't solve the issue with it not touching the pressure plate
I agree, you have the bearing on correctly. Do you still have the old clutch for comparison or did you compare it with the new one?
Yanmar918
Postby Yanmar918 » Thu Mar 21, 2019 8:22 am
The old clutch was toast The main issue is the plate the fingers are not at a correct pitch I can send a picture in of the old clutch
Postby Aaron » Thu Mar 21, 2019 11:12 am
I got your pictures of the old clutch. It looks like you are not checking back for my replies to your support tickets so I will respond here as well. Your old pressure plate looks even worse so I'm not really sure what is causing the fingers to be inverted like that. is it possible that someone machined the flywheel and messed up the dimensions?
And just to make sure.... "Clutch spline long side facing to the rear" means the long end will be facing you when you install the clutch.
Your old clutch picture:
Postby Aaron » Thu Mar 21, 2019 1:39 pm
Here are a couple clutches that are installed correctly. The fingers are almost flat which is pretty much the same as your new clutch setup in your video.
Yanmar918
Postby Yanmar918 » Fri Mar 22, 2019 6:38 am
I don't know what to do . I m pretty sure if I just put it back together ill have the same condition .
Users browsing this forum: Google [Bot] and 13 guests
