2210 Fuel Injector
capnkelly
2210 Fuel Injector
Postby capnkelly » Fri Jan 25, 2019 8:19 pm
I am replacing the head on my 2210D and have a question/need advice/need help on the injectors. I have removed the injectors from the cracked head, cleaned and am about to install them on the new head. Will I have to have the injector chamber upper and bottom pressed in at a machine shop, or is this something that I could do? Also, could I remove the upper and bottom from the old head and install on the new one?
Re: 2210 Fuel Injector
Postby winston » Sat Jan 26, 2019 5:35 am
I have not removed any of these but from reading the 220/226 repair manual I am confident you should be able to install them. Just make sure you get the correct washers and gaskets under them. https://www.hoyetractor.com/support/kno ... rticle=103
Beaub426
Postby Beaub426 » Wed Apr 03, 2019 8:45 pm
They don’t need to be pressed in. They just slide in and are held in by the injector. You should buy new copper washers for them though. Hoye has them.
