1510D quick connect hitch
TownnCountry
Postby TownnCountry » Mon Sep 10, 2018 10:33 pm
Hello, Newbie here from Tampa, FL. just bought first little tractor for small food plots.
Also bought a 4' titan bush hog.
The lower arms wouldn't open wide enough to go on the bush hogs pins so I had to switch the pins around so they point inwards and the lower arms would fit onto pins.
Im wanting to buy a small (4') disc or roto tiller as well and wondering if the quick connect hitch from Harbor Freight would fit on my tractor?
If not can anyone suggest a quick connect hitch that will fit the 1510D?
Thanks in advance for y'alls help.
Re: 1510D quick connect hitch
Postby winston » Tue Sep 11, 2018 8:52 am
I used a harbor freight on my 2002D. Only guessing it wasn't much different than your 1510D.
Postby Aaron » Tue Sep 11, 2018 10:08 am
I think it will fit the tractor just fine. It will add some length which will lower the weight capacity a little. Also be aware that not all implements are actually built to a tight standard like that. I have the Pat's quick hitch on mine which at least allows you to adjust the width and I have had to modify most of my implements (Landpride and LMC) for one reason or another to fit. The LMC box blade was the worst because it had a narrow channel for the lift arms and the quick hitch was too wide and at a slight angle. With a rigid width like the HF hitch it will be even worse. But... once you get your implements setup the first time it is super easy to change them later.
http://www.pats3pointhitchsystem.com/
dagnblond
Postby dagnblond » Wed Jan 22, 2020 6:03 am
I have a 1401D and tried the harbor freight hitch and it would not fit the implements at all so took it back and got the Pat's quick hitch and after a little messing with it to get it right it works great
Users browsing this forum: No registered users and 25 guests
