10 amp motor fuse
matt@callaes.com
10 amp motor fuse
Postby matt@callaes.com » Sat Aug 11, 2018 6:10 pm
I have yanmar 424 that keeps blowing the 10 amp motor fuse. it only has 110 hours on it. does not need to be under load to blow but blows most often under load.
Re: 10 amp motor fuse
Postby winston » Sun Aug 12, 2018 2:35 pm
Don't suppose you have a wiring diagram? I have no idea what the "motor" fuse covers.
Postby Norm » Sun Aug 12, 2018 8:47 pm
What happens when it blows the fuse? The only thing that would stop a diesel engine would be to shut off an electric fuel pump or solenoid.
cmcgee
Postby cmcgee » Sat Mar 16, 2019 11:50 pm
I AM having exact same issue. Did you get yours figured out.
Sa424
Postby Sa424 » Tue Jun 11, 2019 8:41 pm
I'm curious also, what was the problem?
Users browsing this forum: winston and 21 guests
