Hyd hose burst what type of oil do I use
Cyndi64
Postby Cyndi64 » Thu May 10, 2018 8:34 pm
I have a yammar f2200 .what type of hydrulic fluid do I use and the location of where I put it .
O~o\
Re: hyd hose burst what type of oil do I use
Postby O~o\ » Fri May 11, 2018 11:05 am
Cyndi64 wrote:I have a yammar f2200 .what type of hydrulic fluid do I use and the location of where I put it .
You are hi-jacking someone elses thread. A seperate post would garner more response...
That being said, I use J20-C in my 2210D. It is a multi-purpuse hyd fluid. Access to the filler port on mine is between the shift levers.
BTW - I never heard of a "f2200," nor does it appear on a search.
Re: hyd oil leak.
Postby winston » Fri May 11, 2018 2:12 pm
I believe it is an F220 and I have no idea what transmission it has. Cyndia64 posted awhile back and that is what was listed at that time.
Re: Hyd hose burst what type of oil do I use
Postby Aaron » Fri May 11, 2018 2:26 pm
I split this topic off of the original thread. It seems to be enough of an unrelated issue to warrant its own.
