hyd oil leak.
gimpers88
hyd oil leak.
Postby gimpers88 » Wed May 09, 2018 4:57 am
I have hyd oil leaking from around the starter on a YM1500D I believe the front seal of the trans is leaking but I cant find a replacement part number.
can you help me.
Re: hyd oil leak.
Postby Aaron » Wed May 09, 2018 8:12 am
The front seal is #8 in the link below
https://www.hoyetractor.com/CTGY/YM1500TRANSGEAR.htm
Re: hyd oil leak.
Postby Norm » Fri May 11, 2018 7:56 am
gimpers88 wrote:I have hyd oil leaking from around the starter on a YM1500D I believe the front seal of the trans is leaking but I cant find a replacement part number.
can you help me.
If hi/tran oil is leaking around the starter the clutch/bell housing must be filed with oil. Remove the plug from the bell housing and let it drain. If oil has been accumulating for 40 years could be just a minor leak.
Users browsing this forum: No registered users and 10 guests
