YM 1720D stub axle nut socket
imdawat
Postby imdawat » Tue May 01, 2018 7:01 pm
YM 1720D 4WD. What size spindle nut socket does it take to install/remove the wheel stub axle nut (PART # LN-30)? Where can I buy one? Thanks
Re: YM 1720D stub axle nut socket
Postby Aaron » Wed May 02, 2018 9:52 am
The LN-30 is a spanner nut. You typically just use a punch in the grooves and tap the nut around until it gets loose.
https://youtu.be/mby2vq31Q5Q?t=65
imdawat
Postby imdawat » Wed May 02, 2018 12:53 pm
I was hoping for something like this since the last guy beat on this nut so bad he ruined it.
https://images.solomotoparts.com/images ... 0244-1.jpg
Postby Aaron » Wed May 02, 2018 1:01 pm
If you could find one in the right size it would work great. I don't see any sizes listed though. Of course... a new nut is only $5 and that socket is $49. Seems kind of expensive for a one time use tool.
Something like this might be a little more universal but I dont know if you could get it tight enough (or get a tight one loose).
https://www.solomotoparts.com/Motion-Pro-Shock-Wrench/
Postby winston » Wed May 02, 2018 1:20 pm
Not that you need it but they also sell this type. https://www.ebay.com/itm/3-4-to-2-Inch- ... 2438614973
